Quadrocopter Build Thread
Anything that doesn't fit in the categories below or spans a few of them
Postby thesaxmachine » Tue May 22, 2012 9:16 am
Pictures and progress reports for the big build can go here. I will kick of the awesomeness that is group hacking by posting the frames I made over the weekend.
Re: Quadrocopter Build Thread
Postby Bergo » Tue May 22, 2012 9:21 am
really like the look of that black one, has me wanting to upgrade from the wood frame before I've even built it!
Postby thesaxmachine » Tue May 22, 2012 9:58 am
I need to get more of that plastic (HDPE). I didn't like using it before because you can't glue it. But for the quad, I'm using a buttload of hardware to keep it together. It is moving to the top of my favourite materials to work with.
Postby TurmRIC » Wed May 23, 2012 12:01 am
Build Day 1
A box full of quadcopters
All the parts for 1 550 Quadcopter
Fully assembled 550 frame
Al's custom machined frame
Group Shot
550 Frame + control board
450 Frame with control board and motors
450 Frame with motors, escs, and about to get the control board
TurmRIC
Postby Bergo » Wed May 23, 2012 5:50 am
looks awesome guys, sorry I didn't make it out, I ended up working really late, and I had to be up at 4:00 again this morning to drive my wife to the airport.
Postby Hephaestus » Thu May 31, 2012 7:40 pm
Where are you guys getting the 3 pin female to female cables for connecting the receiver to the control board? I had a look at Hobbyworld, all they had were extensions.
Hephaestus
Postby Icars » Sat Jun 02, 2012 11:28 pm
I have some for the build... Did i forget to give you some?....
Let me know and I'll grab some from the box for you.
ICars
Icars
Postby Hephaestus » Sun Jun 03, 2012 1:33 am
Thanks Icars,
I stopped by the space today and Saxmachine dug a couple out of the box for me. im all set that way now.
Query,
the 2 pin header on the PDU board, is that power for the receiver? does it need to be regulated down to 5v for the HK 6a v2 receiver I have?
Thanks
Hephaestus
Postby epoch19 » Sun Jun 03, 2012 2:30 pm
hey Hephaestus,
I believe that the ESCs (HK-HW20A) that everyone got, have a built in BEC supplying voltage/current to your controller board and then to your RX from there
someone please correct me if I'm incorrect.
Also I believe that the 2 pin header on the PDU is for extra peripherals such as LEDs and such on your copter.
epoch19
Postby Icars » Tue Jun 05, 2012 11:20 am
Correct Epoch19!
Icars
Next
Return to General
Who is online
Users browsing this forum: No registered users and 1 guest
cron
