PCB Fabrication Class signup
Post by thesaxmachine » Wed Aug 15, 2012 8:15 am
Planning to hold a PCB fabrication tutorial in Sept on a weekend. Not sure of a concrete date yet but most likely the 3rd or 4th weekend in September. This sign up is just to get numbers if we need to book the Den for space. Reply to this post with preference of date so I can also take that into account.
Re: PCB Fabrication Class signup
Post by Bergo » Wed Aug 15, 2012 8:31 am
either weekend should work for me, I'd like to attend.
Hephaestus
Post by Hephaestus » Wed Sep 05, 2012 12:31 pm
i am also interested. is the class focused on planning a pcb, or creating it, and if creating it, by milling or chemical? interested all the same, just curious
Post by Bergo » Wed Sep 05, 2012 12:32 pm
I'm gone to Nashville from the 12th to 19th, so one of the weekends doesn't work well for me after all.
Post by JamesCooper » Wed Sep 05, 2012 12:51 pm
I'd like to attend, but I'm not sure if I'll be available. Once a date has been set, I'll confirm.
Post by FingerTech » Wed Sep 05, 2012 12:52 pm
Count me in.
Post by thesaxmachine » Wed Sep 05, 2012 1:52 pm
Hephaestus wrote:i am also interested. is the class focused on planning a pcb, or creating it, and if creating it, by milling or chemical? interested all the same, just curious
This class will cover concept to fabrication. The chemical process will be demonstrated for fabrication.
Program to be used is cadsoft eagle. Milling process is just as simple as running a script. I'll have to look into that.
We will try to stick with a single sided board.
Also discuss formatting designs for board house fabrication.
Any requests for what kind of board to make?
Post by thesaxmachine » Wed Sep 05, 2012 1:53 pm
Tentative date of Sept 29
Post by epoch19 » Wed Sep 05, 2012 10:49 pm
This is a great idea. I'm in.
