Hobbyking order
Hobbyking order
Post by DigitalOSH » Thu Jun 14, 2012 5:25 pm
So I'm placing an order and this is the list i have from you guys so far:
Props:
Jeremy Rans: 2x 7x3.5 prop sets
Jeremy Rose: ""
Jordan:""
Bergo & me: 10x 8x5 prop sets
James: 2x 6x5 Prop Sets
Other:
Bergo: turnigy talon2 frame, 5 cf2822 motors
Paul: ""
Jordan: one of the 400mm frame kit motors
10 low voltage buzzers
Rans & Rose: HKC6 charger
What else?
Re: Hobbyking order
Post by epoch19 » Thu Jun 14, 2012 7:39 pm
Put me down for the following:
2x low voltage alarms (if not included already)
6x fc 28-12 motors
1x Prop Saver w/ Band 3mm (10pcs)
2x 7060SF combo (both standard and counter)
2x PolyMax 3.5mm Gold Connectors 10 PAIRS (20PC) ( I think this is what we got last time)
I think that's it.... for now.
TurmRIC
Re: Hobbyking order
Post by TurmRIC » Fri Jun 15, 2012 12:58 am
Put me down just for this stuff instead of what you currently have me down for.
1 x Talon v2.0
5 x Turnigy fc2822
10 x 9x5 prop sets
2 x Bullet connectors
1 x Prop Savers
2 x Low voltage alarm
1 x HKC6 Charger
1 x Charging Lead set
1 x T-Connectors (battery connectors)
1 x Lipo Safe Sack
Which works out to 155.38 before whatever conversion/taxes there are.
Hephaestus
Re: Hobbyking order
Post by Hephaestus » Fri Jun 15, 2012 12:24 pm
i dont know if the 400mm frame motors are the same as the 550mm frame motors, but it's the 550mm frame i have and require a new motor for
Post by DigitalOSH » Fri Jun 15, 2012 3:01 pm
I don't wanna mess it up, maybe let me know exactly which ones you want?
Re: Hobbyking order
Post by epoch19 » Fri Jun 15, 2012 6:57 pm
That's a good idea.
Please add a lipo safe bag to my order also.
Hephaestus
Re: Hobbyking order
Post by Hephaestus » Fri Jun 15, 2012 8:48 pm
here are the motors:
2200kV PM19M-2400:
2800kV PM19S-2800:
and the motor from my 550mm kit:
looks to me like i need a 2200kV PM19M-2400. and 3 prop packs :P
Re: Hobbyking order
Post by Bergo » Tue Jun 19, 2012 2:01 pm
was this all ordered yet? if not, I should get one of those lipo charging sacks as well. Also, I think we need prop saver adapters for our motors Paul.
Re: Hobbyking order
Post by DigitalOSH » Tue Jun 19, 2012 4:53 pm
Good catch. Order is going today, last call!
Re: Hobbyking order
Post by DigitalOSH » Wed Jun 20, 2012 2:32 am
Order Placed, but some bad news. James and Jeremy Rose, your props weren't in stock so I didn't hold out for them
