ATMEGA324 troubleshooting & firmware loading
Anything that doesn't fit in the categories below or spans a few of them
andrewm
Post by andrewm » Fri Jun 26, 2015 2:09 pm
I am in the middle of building the megadrum project (http://www.megadrum.info)
I have the main board built, but I am struggling with the programming of the ATMEGA324 & PIC18F2550.
Does anyone have experience working with these chips?
Thx
epoch19
Re: ATMEGA324 troubleshooting & firmware loading
Post by epoch19 » Mon Jun 29, 2015 2:35 pm
I have some experience working with PIC micro-controllers.
What kind of issue are you having? Are you trying to replicate the device from the link you provided? Can you elaborate on what you are trying to accomplish?
Some basics that might get you started with the PIC18F2550:
1) you will most likely need some sort of programmer (ie PicKit or a third party compatible)
2) the fuse setting on the PIC need to be programmed for the controller to properly operate
3) the datasheets for your micro-controllers are your friends. They may not be intuitive but you can find a lot of useful info in there
Post by JamesCooper » Tue Aug 04, 2015 10:18 am
Sorry I totally missed this post. I have quite a lot of experience uploading firmware to the ATmega. Are you still having trouble with his? If so, drop me a line at james@coopercs.ca.
