July 11th: CNC Ground School
At CNC Ground School you will learn the theory required to generate GCODE files appropriate for Goliath. (Our CNC Router) You will learn about feeds and speeds and how to use the VCarvePro software available to our members. This class is a prerequisite for on-machine training. There is no charge for this class.
July 18th and 25th: Arduino 101
This 6 hour workshop will introduce you to the many forms of input and output on an Arduino compatible microcontroller. You will learn:
- Digital inputs and outputs
- Analog inputs
- PWM outputs
- Digital Communications
The price for the workshop includes an Arduino compatible UNO, breadboard, wires, and a variety of devices to demonstrate and experiment with different styles of Input and Output.
$90
July 6: Build It – Tiny Die
Build your own Electronic Die. Learn to solder and to load firmware onto an ATTiny85 microcontroller. (No programming required, but it is reprogrammable if you so desire.) $60
June 22nd: Soap Making
Learn to make soap at Saskatoon Techworks. ALL required materials will be supplied for this workshop, and you will go home with uncured soap that can be cut into about nine generous-sized bars of Hand-Crafted Natural Soap. $60
June 13th and 20th: Electronics From Zero
This five hour workshop (two Thursday evenings) will take the participant with no experience with electronics and will teach the basics of voltage, current, and resistance. You will learn to build basic circuits and will calculate and take measurements on those circuits to confirm your calculations. $60
May 30th: Soap Making (over)
